ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Pedal Sensor
Old Mar 15, 2023 | 06:44 PM
ahady1193's Avatar
ML 320 model 2001 w163
Pedal Sensor
,hello
i have error in pedal sensor i replied it but still same problems.
HOw can fixed thant
Old Mar 16, 2023 | 09:59 AM
wallyp's Avatar
2003 S500 2007 GL450
Did you replace it with a new or OEM Mercedes part? Are you certain that you have the correct part? The safest way to buy Mercedes parts is to use the VIN.
Used accelerator pedal sensors are likely to already have failed.
Carefully check the connector for damage or corrosion.
