09 ML63 p0452 EVAP code
2002 Mercedes g500
Hi All. New car to me. Seems to be running great. Set p0452 Evap pressure sensor/switch low. Cleared/reset after a few drives. Checked gas cap and o ring. All seems fine.
trying to figure out if this model has an actual fuel tank pressure sensor—looked under tank access panels below rear seats—left side vent tube fitting only—no wiring—right side fuel pump wiring with white plastic lock ring assembly. Wondering if this code could be faulty EVAP solenoid which is super accessible under the hood and cheap? If not, where else should I be looking? Thanks for any advice.
