ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Right Front Level Sensor B22/9 with .49V- Help
Old Oct 11, 2023 | 05:43 PM
JamesMBZ's Avatar
1990 500SL, 1990 560SEC, 2010 ML63, 2007 SL550
Hello, 2010 ML63 AMG. Replaced front right strut (bad ADS) and new relay. New valve block and filter. New Airmatic pump and had to replace the blown fuse. Saw the low voltage on the B22/9 level sensor and changed it out. However, I got the same reading! So, obviously not the sensor. Is there a specific fuse that controls that sensor? I have ordered a new plug, and a one-pin wire, unless you think all 3 wires could be bad? It arrives tomorrow. However, I don't know if that will fix it. Am I missing something?
Thank you in advance!
Old Jul 19, 2025 | 05:46 PM
Bylordus's Avatar
Mercedes e500
0105427617 this is the OEM for the part good luck
