ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Map sensor replacement
Old Dec 3, 2024 | 12:09 PM
m156 rob's Avatar
Hello , I am in need of help changing my map sensor on my m156 ml63 I assumed it wouldn’t be to complicated but it is a tight space and it’s obvious I need to remove some things that are in the way please help me!
Old Dec 4, 2024 | 04:07 PM
Blk63bk's Avatar
Current: 2007 ML63, 2008 CLK63 AMG Black Series
pretty easy job
they are two of them, one on each side after the air filters
hardest part is getting the clip off, which is pretty easy with a flathead screwdriver
Old Dec 4, 2024 | 05:25 PM
m156 rob's Avatar
Appreciate that but I’m talking about my map sensor not the Maf it’s like right in front of my intake manifold
Old Dec 4, 2024 | 05:35 PM
Blk63bk's Avatar
ah, I think you have to take the whole intake off
I'm actually replacing my intake plate this weekend so can confirm then
Old Dec 5, 2024 | 03:59 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
post your vin and I'll see if i can find the WIS procedure
Old Dec 5, 2024 | 06:22 AM
m156 rob's Avatar
4JGBB77E07A175409
Old Dec 5, 2024 | 09:53 AM
TheWichitaKid's Avatar
2014 C63 507 Sedan- Designo Magno Platinum Metallic, 2009 ML63, & 2009 E63
Hopefully this picture is helpful as well. New AMG assembly just installed on my 2009 ML63.
Old Dec 7, 2024 | 09:32 AM
m156 rob's Avatar
Idle air control Valve
would you happen to know where the idle air control valve is located and how hard it would be to change ?
