ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
DAS troubleshooting needed
Old Jan 6, 2025 | 10:38 PM
cgoodwin's Avatar
1988 560SEL, 2003 C230,
2003 Mercedes W163 ML55
Battery was dying and I made several low battery starts, had to charge for an hour or jump to get the truck going.
Changed the battery to a new battery and used the remote to open the door without issue.
Tried to start car and it starts then instantly dies and the odometer displays "Start Error".
I checked the battery again, poked around, locked and unlocked the car with the remote with no issue and the same issue happened when trying to start.
I tried to resync the key as follows:
Doors closed > Key in ignition to pos 2 > Remove key and quickly hold down the lock button while pressing the unlock button 5 times > release all buttons and press the rear hatch button on the fob once. Put the key in the ignition and start.
This time the alarm went off. Removing the key I find that the remote will no longer lock or unlock the doors at all. Repeated the sync again - same result.
Scanned the DAS module with icarsoft > Code reads "Transponder can not be read"
SO there I am, the transponder can not be read and it does not like the radio remote either. Now what?
Remove the DAS and see if it is wet or has poor connections.
I have only one key and Mercedes says they can not get a replacement as they are on backorder.
Ideas?
