ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2009 ML63 – ESP & Check Engine After Engine Wash (Throttle Actuator Error)
Old Jan 11, 2026 | 06:55 AM
Samuelseggss's Avatar
2009 ML63
Hi everyone,
I’m seeking advice on an issue that arose after routine maintenance.
Vehicle is a 2009 ML63.
Both valve cover gaskets were leaking, including oil around the front camshaft sensor. This oil leak damaged my alternator. I replaced all valve cover gaskets and installed another alternator which is used, not brand new.
After the repair, the engine initially ran poorly. A scan showed bad ignition coils on cylinders 5 and 7. I replaced those coils and the engine then ran smoothly.
After that, I took the car for an engine wash. This is something I do routinely after servicing or when the engine bay gets dusty, and I have done it many times before without any issues.
Immediately after starting the car post wash, the ESP light and Check Engine light came on. I scanned the vehicle right away and found multiple ECM and ESP related errors.
I have not driven the car and plan to have it towed home to avoid causing further damage.
I checked the connector close to the MAF sensor and it is tight and properly seated.
Fault codes present after the wash
3699
Fuel Pressure Control
The upper limit value is reached
OBD code P0191
Status current and stored
3619
M16 4 Rear Throttle Valve Actuator
Actual value potentiometer 1 fault
0186
M16 3 Front Throttle Valve Actuator
Output stage fault
0200
Throttle valve position fault
374A
Internal data could not be stored in the control unit
Status stored
Has anyone experienced similar issues after an engine wash on the ML63?
Any guidance on where to start checking would be greatly appreciated.
Old Jan 12, 2026 | 07:02 PM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by Samuelseggss;[url=tel:9252720
9252720[/url]]Hi everyone,
3699
OBD code P0191
3619
0186
Output stage fault
0200
374A
Status stored
Any luck with your situation?
Old Jan 14, 2026 | 05:34 PM
2009 ML63
Yes, I just left the car overnight and the next day it started working
Old Jan 14, 2026 | 10:12 PM
ML 63 AMG
Originally Posted by Samuelseggss;[url=tel:9253976
9253976[/url]]Yes, I just left the car overnight and the next day it started working
Unless you find a crack in a connector or broken wire insulation as the “smoking gun”, I guess it’ll be low pressure engine bay washing from now on lol…! Glad it’s back up and running.
