ML63 AMG (W166) 2011 -2015 (Replaced by GLE63)
Does anyone run 19x10 on W166 ML63?
Old Dec 26, 2018 | 07:09 PM
threeMBs's Avatar
Only MBs - the best or nothing
For winter, off road or for any other reason. If someone does run 19x10 (specifically 19x10, since I know some 19x9 do fit) what offset do you use to clear front calipers?
Old Jan 13, 2019 | 10:44 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
How do you know 19x9 fit?
Old Jan 13, 2019 | 03:43 PM
threeMBs's Avatar
TireRack has a number of 19x9 and 19x8.5 wheels, in low offsets (mid 20s to about 30), that they show fit W166 ML63.
Never seen them being wrong, if anything, found them on conservative side. Lack of replies indicate that none here tried 19s.
Old Apr 3, 2019 | 04:59 PM
threeMBs's Avatar
It FITS!..But barely 1mm space between upper and lower portions of the front caliper: pictured 19x10 et50 wheels required at least 10mm spacers upfront (I used 12mm as pictured below, 15mm can also be used), rears - zero issues (even 18s with proper offset might fit). (No was not done for looks, stock's 21" do look better, but for practicality).
