Ml63 W166 rear door locke
ML63 and ML270
I have 2013 Ml63 and the rear door locked normally and now it will not open by any form..none of the switches or key will not engage. I put a diagnosic on it and simply read an electrical short circuit.
It was fine to this point of time.
the vehicle is well maintained an clean
Anyone have ideas how to open? And possible fix?
thank you
thank you
Try to remove the door panel from inside. There are 2 bolts if I recall and the rest are just the plastic rivet snaps. Think one is by the grab handle and for sure there is one hiding behind the tweeter. Simply pull the tweeter out and you can get to it.
Then prey the panel back to her hand back there to try to unlock. I can’t be much better help from this point. Surely it can be done but 🤷🏻♂️
