2013 ML350 4Matic check engine light on-trouble codes P0442 + P0456....
My check engine light came on. I checked the codes with my OBD2 tester. The two codes that came up were P0442 and P0456.
Here is my question...Has anyone experienced this same problem with this particular year ML350?
If so, I’m assuming replacing the gas cap does NOT fix the problem.
I wanted to start by replacing the O-Ring on the gas cap.
Evap Canister Solenoid O-Ring??
I checkedYouTube- there is nothing on the ML350’s. Thanks for your help! I’m assuming I will emissions with the check engine light on...
Anthony
Repairing/replacing the leaking purge valve.
Unclogging/replacing the blocked/broken purge vent valve.
Replacing the leaking hoses or connectors within the system.
Good luck
thx again!
