F.s..oem 6cd Changer From 02 C32
2003 C230K Coupe Orion Blue
In any case, the buyer will DEFINITELY need them.
2002 C230 coupe , NOt THE AVATAR!!
lemme help you all here..
CABLE YOU WILL NEED:
1. Power Plug
2. Fiber Optic
you can find Power Plug hanging inside your Trim once you remove it, is easy you will see them hanging around. Fiber optic plug you can go get one from your dealer, "if you are asian, use your asian trick make your dealer give it to you free" the install are cakkee![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
i once heard there was a spare set of Fiber Optic cable in your trunk, i need someone to comfirm that tho.. since he has a sedan and i only have a coupe![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1. Power Plug
2. Fiber Optic
1. Power Plug
2. Fiber Optic
1. Power Plug
2. Fiber Optic
the power plug should be in there, if not you can sue benz for that. as for removing it. i have no clue how because i was pulling it and they seems to go pretty deep ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
