Mobile Electronics and Lighting The archived forum for mobile electronics and lighting equipment for sale by members. Browse newer listings and create your own in our new Marketplace.
2005 SL ... adding Sirius
Old Jan 13, 2009 | 08:58 PM
rcoppens's Avatar
R230
I understand my 2005 SL500 is prewired for Satellite (Sirius) radio.
Do I simply add a receiver and I'm all set to activate (Mercedes-Benz part#169-827-0162 or such)?
Old Feb 17, 2009 | 04:30 PM
shawns2006C280's Avatar
2006 C280
I have a OEM tuner and bracket from my C280 that I just purchased, it was activated and used just two months. If you want it I sell it to you for $375 plus shipping. Ill include the mounting bracket also. Send me an pm if your interested
Old Feb 17, 2009 | 09:05 PM
Timeless's Avatar
2005 E55 ///AMG
If it is like my E55, then you will need the SDARs unit and a mounting bracket along with a trunk mounted antenna.
Dealership will want around $1200.00 for everything.
RBrenton (Now Mister Brenton I believe) can get you hooked up on the parts for much less.
Old Feb 17, 2009 | 09:50 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
You will need a reciver, SL completer kit and a antenna. When you get the reciver get a (gen3) unit it has a better repeater so you dont lose signal as much.. and also get the
gen 2 or higher antenna.. as for install its not for a diy but its not that difficult you will have to take the whole rear interior apart and a hole needs to be drilled in the trunk for the antenna so make sure you get a good installer
