Mobile Electronics and Lighting The archived forum for mobile electronics and lighting equipment for sale by members. Browse newer listings and create your own in our new Marketplace.
FS: LIKE NEW JL AUDIO 500/1 V2 Slash MONO AMP (Pics inside)
Old Feb 11, 2009 | 01:17 AM
got_thang?'s Avatar
2008 C350
Thumbs up FS: LIKE NEW JL AUDIO 500/1 V2 Slash MONO AMP (Pics inside)
LIKE NEW JL AUDIO 500/1 V2 CAR MONO AMP. 500 WATTS THE NEW 2008 V2 SERIES
Price:
$320 obo shipped. The retail on the amp is $599 and this is not your typical fleamarket type of amp. Do not get ripped off at cartoys!
Payment Accepted:
Paypal only also local in Houston, Tx local buyers are more than welcome to test it out i am not hiding anything it is in excellent correct working order.
Contact information:
aznrushboy@yahoo.com or pm
Is the item new or used:
NOT Refurbished, Used like new condition. Used for about 3-4months. No electronic defects what so ever. Only minor cosemetics defects very minimum, please view in pics below. Includes everything the 500/1 amp, original JL box, owners manual, Plus bonus extra free Kicker speaker wires
Reason selling:
Part out
Pics (Acutal product not some generic photo):
Product description and specifications:
500W RMS @ 1.5 Ohm - 4 Ohm
THD @ Rated Power : < .05% @ 4 Ohms
S/N Ratio : > 95dB Below Rated Power
Frequency Response : 5 Hz - 500 Hz
Damping Factor
> 500 @ 4 Ohm / 50 Hz
> 250 @ 2 Ohm / 50 Hz
Input Range : Switchable from 200mV - 2V RMS to 800mV - 8V RMS
Class D Monoblock Subwoofer Amplifier
High Damping Class D Circuit with Discrete Control Circuity
Power Supply : Regulated, Intelligent Power Supply with Impedance Optimization & Advanced Rollback Protection
1 Pair of Inputs
Fully Variable, Selectable-Slope Low Pass Filter
2 Channel Parallel with Amp Filter or Pass Through
Bass Eq : Single Band Parametric with Criable Boost up to +15dB and Remote Bass Control Option
Infrasonic Filter : Fully Variable 24dB/Octave From 15-60Hz
Signal Sensing Turn on : Permits Operation without Remote Lead
Accept up to 8 AWG Wire
Accept Up to 4 AWG Wire
Regulated, Intelligent Power Supply system
Differential-balanced inputs
Variable low-pass filter (40-200 Hz, 12 or 24 dB/octave)
Parametric EQ bass boost (0-15 dB at 20-80 Hz)
Variable infrasonic filter (-24 dB/octave at 15-60 Hz)
Optional wired remote bass boost
Class-D amplifier design
MOSFET power and output stages
Speaker- and preamp-level inputs
Preamp outputs
4-gauge power and ground leads and a 50-amp fuse recommended — wiring and hardware not included with amplifier
No on-board fuses — when installing multiple amps in a system, an additional 100-amp in-line fuse between the distribution block and the amplifier is recommended
13-7/16"W x 2-5/16"H x 10-1/16"D
Old Feb 11, 2009 | 01:25 AM
got_thang?'s Avatar
2008 C350
I also got a bnib 2 farad digital capacitor. 30 obo plus shipping
Old Feb 11, 2009 | 11:39 PM
got_thang?'s Avatar
2008 C350
bump
