Sirius Satellite Radio Receiver and Antenna
Never used, never registered, brand new Sirius receiver and antenna with drilling templates for sale.
GUARANTEED to work in prewired W211 (2003-present E-class) and potentially in most other classes.
Comes with brand new, unpainted antenna.
I will include detailed installation instructions - all from my personal installation of an identical unit in a 06 E350.
Save hundreds over dealer prices.
Please PM me with your questions and offers.
The part number is exactly the same as in the installation instructions for the W211 chassis: A2208201797 but I suspect it will work universally in many different MB classes.
PM your email and I will send the installation .pdf
There was no need for any dealer coding, the other (identical) radio just incorporated itself into the MOST network.
Arel11, I sent you PM on benzword.org and you never replied so I don't know if you are prewired or not. Do this:
The EASIEST way to determine if you are pre-wired is to remove the trunk liner and two 10mm screws holding the carrier plate. The carrier plate is located at the back of the trunk, it is a black plastic flat container holding electronic modules. Two 10mm screws are located at the front of the container.
Lift up the front part and have a peek inside.
You can refer to this picture attached to the post #7 in this thread:
https://mbworld.org/forums/attachmen...lectronics.jpg
1. You should see a bright YELLOW optical wire on the left side labelled something like XX14 (both end could be connected to each other forming a loop or connected to some sort of electronic module)
2. On the right side, you should see two ORANGE optical wires, one terminating in the center of the carrier and another one terminating towards the left side of the carrier.
If you see the yellow and orange optical cables in the carrier space you are prewired.
ANOTHER way is to partially remove/fold the right (passenger) side trunk liner and take a look inside, you should see orange optical wires similar to this picture:
https://mbworld.org/forums/attachmen...tall-1-pre.jpg
Let me know and we can go further.
Hi There. I know that you sold this unit, But can you help me out and give me a copy of the installation instructions. I just bought a tuner, antenna from ebay and I want to install them..
