FS: w211 589 14 22 00 Comand Update Disk
there are actually 2 of these update disks......
mercedes navigation sw update 211 589 14 22 00 upgrades the command unit and
Mercedes Navigation Service DVD 211 589 15 22 00 upgrades the trunk dvd unit...
its been a long time since ive done it and sorry to say cant remeber what these disks did.
#14 - updates the command to provide ETA info and enables audio to play MP3's and some other misc updates.
#15 - Updates the system processor when this occurs: "After the new navigation DVD (map) is inserted, the COMAND display shows "NO DVD available, please insert navigation DVD.".
Note: This problem occurs in the case of navigation processors with: - SW09/04 USA (2004.2) or older software-
No, it's not zipped, it's an ISO (disc image).
Use ImgBurn : http://www.imgburn.com/index.php?act=download
Open the program and select "write image file to disc". Use a burn speed ~ 1/2 of cd's max speed rating. (better quality burn).
See above post # 30 for install instructions.
#34
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
#35
Super Moderator Alumni
Any and all requests to "share" or copy COMAND disk is copyright infringement.
MBWorld cannot and will not be a party to piracy.
Further request for copying or sharing copyrighted material will lead to probation, suspension or termination of privileges at MBWorld.
Please go back and re-read the TOU that you all agreed to when you registered here.
