FS: Subwoofer Enclosure for '07-'11 GL
'08 GL450 (P II, ORP, Keyless Go)
Please see https://mbworld.org/forums/gl-class-...r-install.html for original post and pics.
I bought this enclosure from lstoker, unfortunately before checking behind the panel in question to see if it would fit. To be clear, this was not a mistake or fault on his part at all; I failed to check my own vehicle before buying it from him. I am therefore reselling the enclosure.
The enclosure will only fit in the intended space if your GL is not/not equipped with 3-zone AC (rear AC). If you have this option, there is a large compressor/vent assembly behind the panel in question. To check, remove the cover for the first aid kit compartment. Then, use a coin to unlock the two lockscrews on the trim cover itself. If there is a large void behind the compartment, this enclosure will fit your vehicle.
The enclosure will fit the 2007-2011 GL *without* 3-zone/rear seat AC. It *may* fit the 2012. I had the black carpeting stripped off, and recarpeted in cashmere. The interior of the enclosure has also been resealed and tested. The enclosure is a sealed (non-ported) enclosure, 0.3 cu. ft., designed for a JL Audio 8W3v3 subwoofer. A subwoofer is *not* included.
Pick-up/delivery available in DC/MD/NoVA. Please PM if interested.
