Mobile Electronics and Lighting The archived forum for mobile electronics and lighting equipment for sale by members. Browse newer listings and create your own in our new Marketplace.
need help!!!
Old Aug 12, 2014 | 09:52 PM
terry61's Avatar
2000 mercedes c230
need help!!!
Mercedes 2000 c230 is missing around 2500 rpms. I have changed spark plugs, coil pack, and map sensor. What could be causing this? When hooked up to code reader it says cylinder 2 misfire???
Old Aug 12, 2014 | 11:25 PM
516mbtek's Avatar
'06 CLS55 P030
Could be the fuel injector... easiest to switch cyl 1 and 2 injectors and see if fault returns to cyl 2. If problem stays on cyl 2 check compression and then cylinder leakage. Good luck
Old Aug 13, 2014 | 12:23 AM
terry61's Avatar
2000 mercedes c230
ah man thanks! I didn't think id ever get any help on this. It runs real good on low end when your not going real fast, just when it gets up to 23-2500 rpms. I appreciate your help. Ill have him check that.
