Hid kit- no errors w/ video
So far - no errors, looks great, and much brighter than stock. I mounted the ballast outside the headlight w/no issue. Now I'll be the idiot driving to work tomorrow in a $55k car and non-matching headlights.
Pictures will come.
Pictures will come.
Great news that the HID kit working for you. I have 2 quick question if you dont mind answering:
1. How dod you get access to the headlight? Is it through the wheel well? I could see the flap on the whell well and page.115 in the manual says just to slide the flap and lift it. But my truck has a flap and also a plastic screw with flat haed. I didn't know how you took care of this screw? I had hard time to unscrewing it. So I had to cut that plastci screw thing to slide the flap.
2. I got access to the bulb,after turning counter clock wise at the housing, but unable to get it out of the black bulb holder thing. How did you do that? is it a counter clock twist or a pull or something else.
Thanks for your help
Hope this helps.
I went from inside the wheel well however I did not remove the plastic clip. I lift the flap to release from the tabs and then rotated the entire flap. Getting the flap back in place is a lot harder.
Once you turn counter clockwise from the housing pull the entire bulb attached with the wiring out of the housing. You will see that the Halogen bulb is connected to 2 metal holder. 1 part is for the bulb itself and then other is attached to the black platic clip which is used to rotate the bulb into the housing. Pull the bulb along with it's attached metal fitting out of the metal and plastic clip. Once you have the bulb out you need to separate the metal holder that is attached to black plastic connection. You will need to reuse this metal holder in order to attach the HID bulb to bulb housing. You may need to bend the inside of metal holder slightly to fit the HID bulb in correctly.
Hope this helps.
Once you put the HID bulb in, where do you connect the two wires?( The cancellers and the ballasts connected to each together leaving only 2 flat end wires)?
Also...keep in mind that the connections for the ballast/warning cancelers use a 2 pin connection. These pins bend easy and if don't slide the connections in straight they will bend. So if the HIDs do not turn on it is probably a bent pin.
Let me first assure you that its completely normal for that behavior in your ML350.
I got my HID installed by MB technician as I didn't want to take any chance with my new baby. I got the German kit which is little expensive than this kit. After 2 days of the installation my passenger side bulb went out. I got the error" Check head light" and I was really upset. I called the MB technician and they asked me to turn the car off and restart. Amazingly the lights worked fine.
I was told that this is a learning curve for the MB computer to adapt the new lights.
My lights never blink...never ever....
It turns on just like my halogen did.
Hope it helps.....
GA350 - what brand is your German kit?
When I started this thread, I noted no errors or melting issues. It's been about 8 months and I decided to take a look inside the headlamp assbly where I put the ballast and warning cancellers. I only noticed that the warning canceller's shape is slightly deformed. I assume the cheaper plastic construction of the warning cancellers cannot withstand the heat inside the headlamp assembly.
So I decided to place both the warning cancellers and ballasts outside the headlamp assembly. I didn't cut any holes through the rear headlamp cover. I forced the cover back on while the wires were running outside the bottom of the rear circular opening of the headlamp assembly. It's not a water tight deal now at the bottom of the opening but I would assume that water shouldnt enter through normal wet conditions since there is a large lip on the headlamp cover that somewhat overlaps that bottom of the circular opening, even though the hid kit wires are running through this small opening.
I hope this helps those who already installed this kit. I apologize for not taking any pictures at this time.
-Eugene
Hope it helps.....
day one - right side blinks on start up, sometimes doesnt start up at all.. after a restart it seems to work.
day two - brought it back to the shop - after some tinkering, both sides are going nuts, definately not usable at night. i am strongly thinking about returing it to stock..
anyone encounter this problem? and if so how did u fix it?
thanks in advance,
Steven
Hopefully we will be able to fix this via a software tinker.
Beside that they work great once they stabilize.
