2006 C55 AMG Wheel Offset
2006 C55 AMG
Hey Everyone !!!! First Post. Need advice. Looking to upgrade my wheels
on my C55. Does anyone know the proper wheel offset I will need
to clear my front calipers?
2006 Mercedes Benz C-Class 203 Sedan
Bolt Pattern (in): 5x4.41
Bolt Pattern (mm): 5x112
Offset Range (mm): 30 to 46
Front Center Bore (mm): 66.6
Rear Center Bore (mm): 66.6
Stud_Size: 12x1.5
Stud_Size: 12x1.5
2006 MERCEDES C55 WHEELS
This is what I found also. Not sure if the above post is correct, just what I found on the net.
Wheel Specifications
Size: 18" x 8.5"
Style: 5 Double Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 34mm
Part Number: 2034013902
Notes: Rear
Size: 18" x 7.5"
Lugs: 5
Bolt Pattern: 112mm
Offset: 34mm
Part Number: 2034014102
Notes: Front
Size: 18" x 8.5"
Lugs: 5
Bolt Pattern: 112mm
Offset: 34mm
Notes: Rear
Size: 18" x 7.5"
Lugs: 5
Bolt Pattern: 112mm
Offset: 34mm
Notes: Front
