Spring suggestion
Old Feb 12, 2014 | 09:36 PM
DCE320's Avatar
2003 E320
Spring suggestion
Hello friends, hope everyone is well. I've never owned a Mercedes before so I am seeking some help. I have a 2003 E320. The person I got the car from lowered it with Eibach springs. My camber is way off and I see that the car sits too low. I was wondering if I get H&R springs, will it lift it a bit. Also, what can I do about the camber adjustment. Any help and suggestions will be greatly appreciated. Thanks in advance...
Old Feb 15, 2014 | 07:21 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
OTHER ALTERNATIVE TO CAMBER ISSUES AND CONSTANT PREMATURE TIRE REPLACEMENT IS TO FIX IT RIGHT ONCE AND FOR ALL WITH K-MAC
* Free FedEx delivery to MB World Members until 31st March 2014 (PayPal, Visa, MasterCard)
Ex-factory there is only front and rear Toe adjustment for virtually all Mercedes 1968 to current models (and same with Chrysler Crossfire and 300C etc).
We saw the need for owners to be able to return vehicle to factory specs and were the very first company to manufacture precisely adjustable front Camber and Caster bushing kits with twice the adjustment range of the basic one setting offset bolts.
Then for the rear, K-MAC Camber adjuster kits, which have the advantage (unlike upper adjustable arms/DIY kits) of not moving the top of the tire outwards when adjusting to resolve premature inner edge wear - which is an important factor to prevent tires scuffing outer fenders if wide profile tires/rims fitted.
Another advantage with K-MAC rear kits (unlike spherical bearings used in these upper arm kits that prematurely pound out resulting in harsh metal to metal contact) - there's 20 years of proven design and certainly no squeaks.
Also all K-MAC rear Camber adjusters include extra Toe adjustment which is essential to compensate accurately for the new Camber facility! These specially designed Toe bushes also eliminate the unwanted flex of the soft composition and air voids of the OEM bushes further improving handling responsiveness when cornering or lane changing.
The K-MAC patented design front kits replace the 4 main suspension bushes - the unique 2 axis/self aligning design also doubles the load bearing area thereby increasing wear life and also steering and braking response.
Similar design is used for the 4 main rear K-MAC bushings.
Result is precise single wrench front and rear (ongoing) adjustment to importantly return vehicle to factory specs to improve traction, compensate for steering pull, costly inner edge tire wear through altering height, fitting wide profile tires, load carrying, curb-knock damage and/or the advantage of being able to alter specs, improve lap times on track days and with genuine K-MAC you also do not need to purchase special fitting tools.
Product confidence with K-MAC is further assured by our total, ongoing commitment to motor racing - all out 10/10th competition testing keeps K-MAC products always at the forefront re cutting edge technology, proven strength and durability.
