SL 500 hydraulic problem
Old Jun 27, 2014 | 10:24 AM
mdejarnette's Avatar
1999 SKL 500 and 1999 C280
Had a leak over the driver side window; eventually the entire system stopped working (windows still work though); here's what I need help on
- How do I close the rear latches on the soft top manually?
- How do I install the hard top manually?
- Can I replace the cylinder over the visor myself, and finally,
- Can I get it refurbished w/o buying a new one?
Old Jul 11, 2014 | 08:08 AM
afrts's Avatar
1995 SL320
Rear latches..it's in the owners manual..there should be a special wrench in the trunk.
Instructions are in the owners manual for the hard top.
Yes you can "Repair" the Cylinders over the windsheild your self..they are easy to do and will save you a lot of money..all that needs to be done is to replace a small seal inside. Their are instructions for this and a place to order the kit from on youtube.
Hope this helps..and Happy Motoring.
