rough idle stalls 4.5 v8
Old Sep 4, 2014 | 10:48 PM
cljetton2's Avatar
1972 350sl
Question rough idle stalls 4.5 v8
I have a 1972 mb 350sl had a engine fire ,repaired
and ohms tested all connects for efi engine harness .
has new injectors ,new cold start valve new spark plug wire set plugs ,cap and rotor . timing is dead on and points are adjusted within factory dwell. vacuum leaks are all repaired , pulse generator points are clean . when I rotated the throtle positon sensor I can not hear the injectors clicking with key in start position. engine starts then dies , when given more throtle it will smooth out at 3500 rpm . New intake gasket and booties . Im at a loss somebody come to my aide
lee jetton
retired cw2 army
