2001 ML320 ABS and Check Engine on
Old Aug 13, 2015 | 11:04 AM
lbados's Avatar
2001 Mercedes ML 320
Exclamation 2001 ML320 ABS and Check Engine on
Hi
Can anyone help me with this?:I have a ML 320 2001, my ABS and Check Engine goes off after start,every morning , ,i figure that if I left truck warming up for 15 min and then trun it off and back on , the ABS light goes away but not the check engine, if I try to run it with the ABS on, truck wont shift , so I have to turn it off and back on so the ABS light goes away, until then I can run it normally even if the check engine is still on and I will be ok all day, took truck to Orelly and the check the computer codes, it showed that I had p0720 (replace wheel speed sensor) and p0600 Serial communication link,then I took it to the mechanic and he said I need to replace the rear sensor only, witch I did,they reset the computer by disconnecting battery and light went away and didn't had any more lights comming off that day ,but in the morning ,problem came back and same lights were on,can some tell me if they are having or had this same problem?
thanks
Leo
