2007 E350 Electrical Issues- COMMAND
Old Feb 18, 2016 | 12:10 PM
Drew Beck's Avatar
2007 E350
Hey there,
So one day as I was loading my trunk, I closed it and when I went to reopen it with the key fab, it would not open. Using the button inside did not work either. I thought maybe something was stuck in the latch, but was able to open the trunk with the manual key slot. My car now notifies me that my license plate bulbs do not work (they don't) and my third brake light does not work (it does). I then checked fuses and from what I could tell (i'm not a car expert), they were all fine. It appeared as though 11 & 12 were the ones associated with the trunk. I had done some research and found that there have been people with issues like this and found a problem where the trunk actually cuts the wiring. If you have any expertise in this, please let me know.
However, the main reason I am writing is because after checking the fuses, my COMMAND unit stopped working. It was working prior to touching the fuse unit, but then it started just coming up with the emblem and shutting off. Now nothing happens. If you know anything to help, that would be great. Listening to my phone in the cupholder is getting a tad old.
Thanks,
D
Old Feb 18, 2016 | 12:37 PM
Settthhh's Avatar
2006 C55
Oh geez, welcome. Post this in the E350 forum, they will be of more help!
