Possible SBC Problem
Recently I've been driving to work and back more often which is a 46km commute and I noticed a shudder on the steering wheel on 2 occasions. The shudder is caused by both the font calipers binding on the disks. No brakes applied when shudder is felt. This causes great heat build-up to the point where on the last occasion the brakes failed completely due to the brake fluid reaching boiling point.
I have no warning lights or messages on my dash indication anything abnormal. I assume the workshop will not be able to read off any fault codes, otherwise it would've shown some warning to me when the brakes failed. I've tried to read up as much as I can on the SBC system on the vehicle and I suspect 1 of 2 things. The problem is not with the calipers, because common sense tells me they will not fail or bind both at exactly the same time. The problem is either caused by the SBC software not releasing the brakes completely or by a sticking solenoid inside the SBC control unit.
The vehicle is at an independant workshop at the moment and awaiting their diagnosis, I'm doing some research on the forum as I understand that a replacement SBC is almost half the cars value.
If anyone has ever had this problem, please tell me how you got it resolved.
Heinri
