2005 C 320 Sport Coupe fuel tank issue
I recently purchased a 2005 C 320 Sport Coupe. When I fill the gas tank up it only fills up half way then refuses to take in anymore gas. Is there something at home I can do to fix this issue?
Is it the tank or the gauge? when you fill it does the gas Nozzle click off. If the Nozzle clicks off and it won't take anymore but the gauge shows half then I suspect it's the gauge. A little process of elimination on your part and I'm sure you can figure out if it's the gauge. Keep in mind the car is 13 years old stuff does break :-)
The nozzle cuts off at 21.00 every time. I'm trying to not spend an arm and a leg to fix it. If there is a at home fix that you, could recommend, that would be great.
