Having a few problems with my 1983 300SD
Old Apr 5, 2018 | 01:03 PM
cyndee60's Avatar
1983 300SD
I'm having a few problems with my '83 300SD which just had a lot of work done a couple of months ago: new engine mounts, shocks and struts, and vacuum pump to name a few. This may be all unrelated, but yesterday my sunroof wouldn't move although I can hear the motor whirring when I toggle the switch, my gas gauge needle is wriggling all over the place, and my manual armrest won't slide up and down. Like I said, likely unrelated, but if anyone has any input while three things would fail simultaneously (other than bad things coming in threes), I would be grateful. I can only do so much research myself before confusion and exasperation set in. The car is in very good shape for its age, and I am only its third owner but I hate to pour a whole lot more $$$ into it at this point. Thanks!
Old Apr 5, 2018 | 01:50 PM
oldsinner111's Avatar
s320
Make sure your engine ground is good,these old cars ground thru the body too, I always add extra ground strap,from batt to motor block,and block to body. Use the ratchet in the trunk to open sunroof,and lube the track,and clean it. I use atf for it.
