Garmin MAP Pilot SD Card A218-906-30-03
Old May 3, 2018 | 04:01 PM
Rusty G's Avatar
C300M
Greetings. I'm in the USA with a brand new C300 (build date 4/20/2018) which is pre-wired for Nav. Does anyone know where I can obtain the correct SD Card at a reasonable price, which, according to the local MB Dealer is A218-906-30-03 at $630.00. I tried the A218-906-20-03 which is freely available, but is not recognized by the nav when the card is inserted into the slot. Any help would be greatly appreciated. Thanks in advance.
Old Jun 27, 2018 | 11:41 PM
t0lkman's Avatar
Ford Edge
I am in the same situation, I found this https://www.ebay.com/itm/2018-Merced...IAAOSwVF1aJ0Ms
what do you think? Should we buy it?
Old Jun 28, 2018 | 11:37 AM
Rusty G's Avatar
C300M
Thumbs up
I eventually discovered the card ending in 20-03 and 30-03 will both work in my situation. The reason the the 20-03 failed the first time was the card itself was defective. I received a replacement 20-03 and it worked just fine. I have also successfully updated the card to the latest version, 8.2. This is where I bought the replacement card: https://www.ebay.com/itm/OEM-Mercede...72.m2749.l2649
Good luck!
