C63 amg esp module failure
Old May 9, 2018 | 12:31 PM
Elliot6383's Avatar
Mercedes c63 amg
hi, I’m new to this and really hoping someone can help me.
i have a 2008 c63 amg, I had the abs unit sent of for testing with ecu testing, they have said the processor is faulty and the unit can’t be repaired.
can I fit a second hand one to the car? I can see plenty for sale on eBay but the one I have in my car has completely different part numbers to the ones on the net, the ones on the net mostly seem to have the same part numbers?
thanks in advance!
Old May 9, 2018 | 01:20 PM
Elliot6383's Avatar
Mercedes c63 amg
Whining? I was asking a question wasn’t I? As long as vin number part numbers are same they usually work, simply asking a question, isn’t that what a forum is for?
Old May 9, 2018 | 01:53 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I recommend you use the search feature first. In the vast majority of cases the answer has been provided multiple times to the exact same question. After awhile, it gets old.
If you purchase a used ESP module it should have the exact same part number. There may be later versions with updated part numbers that are arguably better for your car. Use your VIN at a dealer (or you can ask online here. I recommend you post in the C63 amg sub-forum, not in the new member sub-forum). Any member of the forum with access to EPC (remember, internet search! Hint: Mercedes EPC.) can confirm the proper part number(s) that will work on your car. If you can't get an answer in the C63 sub-forum, look me up on the E55 sub-forum.
Old May 9, 2018 | 02:06 PM
Elliot6383's Avatar
Mercedes c63 amg
Thank you for your reply! I’m new to all this so I’m just getting to grips with it all, I will post the vin number and see what comes back, thanks again!
