Dpf P244A code help
Old Jul 8, 2018 | 07:52 AM
Shane W204 2012's Avatar
Mercedes c class 2.2 vid blue efficiency
Dpf P244A code help
hi Guys,
I own a Blue efficiency c class 2.2 cdi 2012 W204 and it recently started losing power, I (stupidly I know) tried to diagnose the issue myself and subsequently changed the MAP sensor followed by the complete MAF unit. Now I’m getting another code P244A on my reader.... the engine doesn’t seem to be getting to temperature (it normally runs around 90 degrees but now fluctuates between 70-80 degrees) My question is this: Do I need to change the Dpf sensor and if so where is it located? Any help will be much appreciated. Cheers, Shane 👍
Old Sep 19, 2018 | 02:52 PM
Gazwould's Avatar
S204 C250 CDI Sport
I'd start with a new thermostat .
Trouble is with a dpf is everything has to be 100% working , any fuel mixture enrichment caused by maf , egr , poor condition air filter , boost leak , thermostat etc will lead to a shorter dpf life .
It's flawed...
