r129 320 sl misfire on tickover when hot
Old Aug 8, 2018 | 02:16 PM
chezman998's Avatar
1994-5 sl320 r129
please someone help I have a 94 sl 320 104991 engine,when it gets warm it misfires worse at low rev,s when u click her in gear,please read what I have done before you send me your reply,ok here goes,new wiring loom,new coil packs new plug leads,new plugs,new air flow meter,6 injectors,new ecu,scanner said misfire on cylinders 1 and 2.also new engine fitted as timing chain broke.the symptoms are a werring noise on front of engine after belt removed hope this helps any other merc owners
