Problem with ECM
Old Apr 30, 2020 | 11:10 AM
Kenoby63's Avatar
Mercedes c class cdi 220 w204
Problem with ECM
Hello guys! I’m new member and I have mercedes c class 220 cdi w204 , 2008 an I will attache a picture wit the result of tester! Just if you have ideea what parts or what can I do to fix this problem! You must know, when my car go in limp mode on board appear orange triangle for ESP and I can read esp innoperative and the light malfunction, bu now it is strange:if I switch off the engine , after I switch on again the triangle dissapear but malfuntion it is stil on, now if I repeat same operation another twice, a 4th time when I switch on , mirracle malfunction light dissapear and everithing is ok! I mention that this problem occurs when I try to accelerate suddenly between speeds 4-5 and 5-6! Any suggestion please ? Thank you![img]blob:https://mbworld.org/361bf32f-20af-40fe-a86c-54bd8d721318[/img]
This is the redult after test
