Head Rest Removal w221
Ugh I need need more coffee this doesnt even make sense to me)
Carefully pull of the back cover off. This will expose the powered headrest height motor to which where the 2 headrest post pop into.
Lean your seat way back for clearance, gently tug on the headrest to loosen the, from the motor.
Opposite for reverse but be sure when you slide the headrest back in that you get both of the post to sit directly in the locations on the motor. If you decide not to remove the back cover, you will be guessing if the headrest got in their respective locations. If you force it in without lining them up, you can accidentally break the delicate plastic on the motors post mounts.
