Rattle from behind LCD panels
Since new I've had a rattle coming from behind my lcd panel in the center. I waited until Service A to have dealer look into it. Of course they could not replicate it. It happens particularly at around 1100 rpms when steering wheel is slightly left of center. Anyway, got my car back and decided to look into it myself. Removed panel using instructions below..
Did not disconnect any cables. Just looked around for anything loose. Did not find anything so put everything back together ensuring I firmly tightened the 3 screws (which were not very tight actually). Took it for a test drive and no noise. Reseating it may have done the trick.
Worth a shot if the rattle annoys you.
Hope this helps.
Hope this helps.
The following 4 users liked this post by Merserybenze:
2019 S560, 2022 Audi S8
https://www.youtube.com/watch?v=_cei3LzK38g
Hope this helps.
Hope this helps.
spoke too soon. rattle came back. opened her up again and put foam tape over everything I could see might be rattling...still there. I wonder if it's inside the lcd panels....I guess I'll have to take it to the dealer, unless anyone else has any ideas?
2015 S550 4Matic
Do you have Heads Up Display. The plastic cover, above the dash, sounds like "radio static"(very high pitched) on mine. You can put your hand on it to stop vibration. Hopefully at my next dealer visit they will have a fix?????
With the assembly removed but still connected ( I assume ), cant you bring the car up to the 1100 RPM and move the wheel to the location you stated? Or is it only when driving... Just curious.
I did that and it didn't rattle. It appears to be when the lcd panel is screwed into place. Tomorrow I'm going to try putting some packing foam behind the panel before re-assembling it.
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
I would put everything back together exactly how it was and take a video of the rattle sound and then bring the car and video back to the dealer and ask them to find the problem. You could potentially void some warranty by removing the LCD panel.
W222 S550e, C207 E550, W212 E350
I have an annoying rattle in my HUD. I've taken it to the dealer multiple times and have many videos. They don't want to take apart the whole dash so everytime I take it in, theres nothing they want to do about it. The last time I took the car in for the rattle complaint, they asked me if I could authroize the GM to joy ride in it all weekend so I hesitantly said yes, hoping he would hear it. Nope
s550 I had the hud rattle and three times to the dealer. I ended up fixing it myself. I took felt and placed it around the cover edge that touches the plastic lense on the hud. It adds pressure to the lense and no longer makes noise.
The following 2 users liked this post by Katie22:
jumpman726 (07-26-2018),
S550e (08-10-2018)
One last try - removed panel and put sponge sheets behind panel before re-assembly. i'll give it a few days to see if it worked.
I feel your pain. Immediately after I bought my car 16 months ago the rattling around the plastic covers that are in and around the rear view mirror where all of the cameras and sensors are located rattled something terrible. I had to jam black rubber/foam material along the seams to stop it. The other rattles in the right rear area of my car are either coming from the pano roof or they are coming from within the C pillar /roof areas where possibly airbag components are not secured well enough. I've learned to just ignore it. My W221 (2007 S600) never had a single rattle or squeak. They have definitely dropped the ball in quality of build on the W222 compared to other models. That being said, when I test drove a 2018 S560 a month or two ago, I was amazed at how quiet it was in terms of lack of interior squeaks and rattles.
removed the cluster (Duo LCD unit) totally and put it on the back seat. Removed ac vent in front of LCD panels. drove it and still heard rattle coming from the dashboard. I give up. Have an apt with the dealer later this week. I can say I tried!.
Fixed! Dealer kept the car for a week and tried various things including removing most of the dash. In the end it was the HVAC connection to the ventilation system under the hood near the windshield in front of the passenger side - under the cowling. Technician put some adhesive felt between the joint and it fixed it. Car is back to a quite vibration free drive.
monkey9cars (05-26-2023)
Yup497 (11-10-2020)
Hello,w205 owner here.
After a year of use i've noticed all kind of sounds inside during driving(our Croatian roads are.,...on the bad side)....went to sound isolating jihad(aka holy war lol)
Located 4 main sources of squeaks:
Piano black console/command display.
Casing of cluster gauges(loudest)
Prolly a glovebox but still to investigate more
Doors(sometimes),usually during SHARP turns or fast acceleration/breaking
Till i find where to buy felt tapes in Croatia i played around command display and found a quick and cheap solution,dunno how to say it on English: tiny rubbers
One longer for whole circle around diplay/dashboard joing...it will almost completely slip inside that joint,then i took two black,shorter ones and padded that slip ins from passenger side and driver side(more demanding due to steering wheel in the way.
Aesthetic is great u don't see them,rattles and squeaks from smaller bumps completely eliminated from the center part of the cabin.
Now God help me with others
Received 3,418 Likes
2012 CLS63
hyperion667 (11-06-2020)
