W222 S550 spare tire
I am not confident in the run flat tires I have on my S550. They are 22” wheels and the trunk does not have a place for a spare. I wanted to check with others to see if they found a solution to this.
Thx, John
Thx, John
General Understanding ….
I have personally been thinking of going with Full Summer (Non Extended Mobility) Not Run Flats, separate discussion.... and full Winter Tires since I am in the NY area. However, I am stuck with the following.....
1. Stay with Extended Mobility All Season Tires Rougher ride, great steering response, risk damaging rims due to stiff sidewalls, no need to extra set of rims, no need to swap tires, long tread life, good balance in Dry/Wet/Snow conditions.
2. Get Winter Extended Mobility Tires and Summer Extended Mobility Tires. Stiff ride, Noisy, short tread life, (Winter, BEST FOR DRIVING IN SNOW AND SLUSH ( Almost 50% better in Traction and STOPPING distances.) Summer, BEST FOR DRIVING IN DRY/WET ( Almost 50% better in Traction and STOPPING distances ) Risk of damaging Rims due to Stiffer Side Wall.
3. Get a W221 Spare, eat up limited trunk space, Install Standard All Season
4. Get a W221 Spare, eat up limited trunk space, Use Non Extended Mobility Summer tires, *** However, they are noisier, and have thicker side walls and minimum useful thread life.
. . . and the stories, comments will go on and on and on and on....
Bottom line...…. Its a Personal Choice once you have all the data.
If stopping distances are most important, True Summer/Winter Extended Mobility or not.
If Noise / Comfort is most important, Non Extended Mobility, Non Dedicated Summer/Winter
If Rim Damage is biggest concern, Non Extended Mobility, Non Dedicated Summer
Yadda, Yadda, Yadda...
The above is my general observation from reading through tons of Zero's and One's...
Now, lets get the Nitro Fill going again...
Extended Mobility Tires are not Run-Flat
https://www.tirerack.com/tires/tiret...jsp?techid=234
jpaul4 (02-10-2019)
I have been a Mercedes addict for a while. Now there is neither a spare tire nor a CD player in the Sedans.
Goodbye Mercedes. My new car list now has BMW, Audi, and Genesis models which I research as my hobby.
I'll insist on a spare and a CD player and probably get run flats also when it is time to buy.
The lack of a spare tire is the only complaint I have with the W222, other than that I love it. Rides great and no service issues. If you drive on a run-flat w/o air it pretty much destroys the tire. I don’t trust a run flat to get me to a safe location if I get a flat while on a trip. The minimal savings in space/weight & cost do not justify the elimination of a spare.
The following 3 users liked this post by jpaul4:
jpaul4 (02-10-2019)
The A8 is a nice car, I considered it before purchasing the W222.
Received 3,740 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
With 22” wheels and the “rubber band” profile tires they require on a W222, you are just begging for trouble, but I’m sure you know that. I run non-run flat tires and carry a W221 compact spare, which sits on top of my trunk floor. It’s a nuisance, but provides great peace of mind, especially when traveling outside a metro area.
RussT (02-28-2019)
The desire for a spare in W222 cars is quite strong on these boards, but that & $5.00 will get us a cup of coffee. So, make a point of COMPLAINING about this, EVERY time you interact with ANY MB employee you encounter. From sales staff, to service writers, to anyone you might talk to at MBUSA. TELL THEM how unhappy you are and that your next car may be a BMW, Audi or Genesis, JUST because of this issue. If MB were to hear this enough times, they would fix the problem. A compact spare should, at the very least, be optional on a car the size and caliber of an S Class.
Holtgraver (11-22-2019)
If you must drive further than 50 miles to reach help, do so. The downside is the distance driven beyond 50 miles reduces the probability the tire can be repaired.
Currently running on Bridgestone Drive Guards. Very satisfied with them. But the best part is knowing I will never be disabled on the hard shoulder, lying on my back with semi-trucks passing by three feet away at 70 mph. Damm scary!
Nice Ride (02-11-2019)
Even though I carry a spare, I don’t plan on changing it myself anytime soon. If I get a flat, I’ll call AAA or MB Roadsise Assistance. However, IF the tire cannot be repaired onsite, I will have a spare for the service to install. If the tire cannot be repaired and you do not have a spare, you are going for a ride in the cab of a tow truck. Depending on where you are (family trip to Yellowstone?), this could be REALLY inconvenient and might take more than a day to resolve. I know that such things rarely happen, but as a Boy Scout, I learned to always be prepared.
I take some nice trips once in a while in my s class and dont want to wait for anyone in case i get a flat. I have the same setup as steamliner. spare in trunk w full 221 jack kit.
i will get a spare tire and keep in trunk with jack. Unfortunately, when going on a family trip I’ll need all the trunk space it has for luggage. I may either take a different vehicle or roll the dice.
I also considered the Audi A8 with the standard tires and spare in the trunk. But the reported history of catastrophic engine failure/ turbo issues with the Audi 4.0L turbo engine (which apparently has been remedied after 2016) kept me from pulling the trigger.
Donnymac (05-17-2019)
I joined the spare tire-equipped W222 owners. Bought a full size Pirelli tire on 19x8.5 wheel, as well as electric jack with lug wrench. $700 & lost most of trunk. However, I am now confident to venture outside city limits!
I think we should all send photos of our trunks with our spares sitting in there to MBUSA.
The following 2 users liked this post by Streamliner:
Donnymac (06-09-2019),
seamus2154 (02-28-2019)
I will be getting a spare/jack as soon as I swap out the run flats. It a shame we all need to do this.
It certainly should get some attention and change in the US models to include a spare in the future. From what I read on this forum many object to the elimination of the spare, I wonder if it’s the same in other countries? The worst part is it occupies so much of the trunk, but it was designed underneath the trunk like most vehicles it would be fixable.
Hello all,
I am in the process of buying a new 560 and have been doing the usual forum searches and such.
My .02, we have had 3 incidents of an unserviceable tire damage in our family over the last 50 years.
I have plugged a tire about 8 times, usually a slow leak from a nail or such.
I usually swap out run flats for non run flats when the RFs need replacement.
I do carry a small compressor and tire plug kit in the trunk.
If a spare tire is available from the manufacturer, I get one. Used that about 3 times in the last 50 years.
I don't think it is necessary to sacrifice trunk space to carry a spare............
I have been driving for over 50 years now and have never been stranded with a tire issue! I did get a nail in one tire but TPMS allowed me to get it plugged before it went flat. When my RF tires wear down I plan to replace with conventional. I do carry a pump and plug kit in my trunk.
so interesting, wife came back from work w a flat, no idea how she drove on it sidewalls gone now. Call up my tire place and ..... conti dws 315-35-20 on national backorder! yea *** me! tires have low miles on them as I put them on last year. Luckily found a new one on ebay after calling everywhere will be here in a few days but until then ill use the spare. Thankfully I sourced it when i bought the truck a few years ago, turns a prblm not into a prblm. So this was for my x5 but easily could have been any of my cars.
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
Aren't women great??! My wife did the same thing twice. We recently counted all the rims she curbed in the last 15 years......11 !! After my last explosion 4 years ago she never asks to take my car anywhere for any reason now. LOL Works for me. She hasn't curbed a rim in 4 years...I feel blessed!! Sucks when it's a low mile tire. Good luck
yea does suk... the " new tire" i bought on ebay was date coded 2011 so I cancelled that..... Id like to keep the conti dws all around so ill keep looking.. measured my current which is at 8/32...
