Other Cars Discussion of non Mercedes Benz vehicles
Full System Diagnostic Tool - Launch X431 V 8inch
Old Dec 18, 2017 | 03:29 AM
kingbolen2017's Avatar
volv
What is X431 V Original?
X431 V is a new diagnostic tool released by Launch tech. It is composed of an X-431 V pad computer, a protection sleeve, a DBScar diagnostic connector and many OBD1 to OBD2 connectors. It communicates with your car by connecting DBSCAR with Bluetooth, it reads car DTCs and perfoms diagnosis by the X431 Pro Pad computer, it achieves X431 series full car model and full-system diagnose function, it can replace X431 Diagun III or X431 IV. Meanwhile, taking advantage of mobile internet, it integrates more application and service, such as creating maintenance data base and case library, providing instant maintenance information, establishing public and private maintenance social circle etc. As a result, it builds a broad vehicle diagnostic community, which helps you to share vehicle maintenance knowledge online, exchange vehicle maintenance experience online and provide vehicle maintenance related service support online. This will be another revolution raised by Launch in the vehicle diagnosis industry.
Powerful diagnosis Function:
1. Full Diagnosis Function:
X431 V can diagnose the electronic control system of prevailing vehicle models covering Asian, European, American and Chinese. Full range car models and full car system diagnosis make it a professional automotive diagnostic tool.
Diagnosis functions include: Read DTCs, Clear DTCs, Read datastream, Special functions etc;
X431 V-series product have so many advantage such as widely coverage at vehicle model, powerful test function, more special function, more accurate test data etc.
1.With special function such as for BMW idle study, for BMW injection rate adjustment, for BMW battery replacement, for Nissan matching key.
2.In addition to support for Benz, for BMW, for Ford and other mainstream models, also support for IRKIA, for PERODUA, for Proton, for TATA, for Maruti, for Lancia and other domestic model from all over the world.
3.Full system Diagnosis.
Launch X431 V Special Function
This option allows you to detect whether the system parameters are normal or not. It mainly includes: Injector test, fuel pump test, purge control solenoid and so on.
Take "1# injector" as an example. To detect whether 1# injector works normally or not, tap "1# injector", the system will automatically carry out the function. After complete, a prompt dialog box will pop up on the screen.
Reset Service
In addition to amazing & powerful diagnostic function, X-431 V also features various service functions. The most commonly performed service functions contain:
Oil Reset Service
Steering Angle Calibration
Electronic Parking Brake Reset
Battery Register / Battery Maintenance
ABS Bleeding
Electronic Throttle Position Reset / Learn
Diesel Particulate Filter (DPF) Regeneration
Tire Pressure Monitor System Reset
2. Connecting by Bluetooth
X431 V communicates via Bluetooth, it is very easy to use. X431 V Pad computer is specially designed for Android platform with clear and user-friendly interface. X431 V Pad computer is equipped with an exclusive X-431 V protection sleeve to prevent it from being damaged;
The owner can use golo connector to connect to his smart phone, then he can do a all system fault diagnosis of vehicle at any time, then form a diagnosis report, and transfer the report to maintenance technicians and related personnel through the account management interface, then he get the remote consultation and repair advice.
3. Browser:
Built-in Wi-Fi module makes surfing on the internet freely;
4.Settings:
Through the settings, you are allowed to configure the personalized X-431 V;
5. Search:
Enables you to locate your target quickly and conveniently;
6. Email:
Allows you to send and receive email. External POP3 or IMAP email account for some common Web email service provider can be added;
7.File Manager:
You can manage the files or downloaded files stored in SD card efficiently;
8. Other Additional Functions:
Alarm, calendar, calculator etc.
9. Applications:
Other android-based applications can be customized to install or uninstall.
Operating system:Android 4.2
CPU:1.3 GHz
Display:8"TN capacitive touch screen
RAM:1 GB
Capacity (internal / SD card):16GB
Battery:4290 mAh
Printer:Optional (Wi-Fi)
Camera:Front 2 mp / Back 5mp
Communication:WiFi/Bluetooth
