Parting Out 300SD
Parting Out 300SD
Have many new parts bought for a 1984 300SD that are not needed. Want to sell all parts in one transaction. Great deal for someone!! Have most parts for a front end overhaul minus springs. Due to weight must charge $35 shipping to anywhere in the USA. Will not ship outside of USA. Cannot guarantee that all parts will fit your particular application as I never installed them so I cant confirm that they are for a 126 chassis. Price $400.00 plus shipping.
Parts are:
1. Mann Oil Filter #PF 1055
2. 2 Maule Fuel Filters
3. 2 Pre Fuel Filters
4. Fuel Sender Gasket(Tank) #107-997-13-45
5. Radiator Drain Plug #000-501-01-71
6. 3 Hollow Bolt Seal Rings #003-997-58-48
7. Set of Sway Bar Bushings #126-323-01
8. 2 Control Arm Bushing Kits #126-330-0075
9. 2 Upper Control Arms(Left and Right) #126-330-0607
10. 2 Lower Ball Joints(Febi) #116-333-09-27
11. Idler Arm Repair Kit(Febi) #126-460-08-19
12. 2 Eccentric Pin Kits #116-330-10-18
13. 3 Tie Rod End Kits #126-330-06-03
14. 1 Center Tie Rod Kit #126-460-0805
15. 1 Bilstein Steering Dampner #B22-0246-BM
16. 2 Guide Rod Repair Kits #123-330-14-75
17. Rear Crank Seal #001-997-12-41
18. 1 Front Crank Seal #107-997-13-45
19. 1 Bosch Voltage Regulator #1197311028-850
20. Mercedes(OEM)Brake Pads #001-420-99-20
21. 2 Front Wheel Seals #010-997-65-47
22. 3 Front Dust Caps
23. 3 Brake Anti-Rattle Springs #000-421-24-91-64
Parts are:
