Parting Out Parting out threads by members.
2011 w204 C300 Engine Partout
Old Jul 28, 2012 | 05:05 PM
Aboshi's Avatar
2007 GL450
Hi everyone,
I had to replace my 2011 C300 4matic Sport engine so I am parting out the original. This is virtually a complete motor less the motor mounts, and a few other little odds and ends that I needed for the new motor I got. The block does have 2 holes in it so if you want it as a replacement or a project it would need to be welded. These parts only have 7332 miles on them. I will get some pic up later this week if any of you are interested
list of parts if anyone needs:
Heads
Headers
Valves
(3) Coils
Crank Shaft
Flywheel
Water Pump
Oil Pump
Cams Shafts
Valves
(5) Pistons w/rings
(5) Piston rod w/bearings
RWD Wiring Harness - (has a few broken connectors)
Timing Chain
All Sensors
RWD Oil Pan
(6) Fuel Injector
MAF
Intake Manifold
Flywheel
I'm sure I'm forgetting a lot of stuff but its the entire engine just let me know what you need and I'll pull it off so dont hesitate to ask
Old Feb 11, 2013 | 08:46 PM
ggms16's Avatar
2009 C300 4Matic Sport
Happen to have the tranny?
Old Feb 11, 2013 | 10:25 PM
Aboshi's Avatar
2007 GL450
sorry no tranny, also thread can be closed the motor was destroyed durring hurricane sandy ;(
