Parting out Weistec Stage 2 Supercharged C63 AMG (W204)
9 Attachment(s)
Hi there,
I sadly parted out my 2013 C63 AMG and have some quality performance parts available for sale, which may be of interest to some of you. I have pictures which I can send to anyone sending me a PM request. x C63 AMG Weistec headers M156 engine Please don't compare these to other brands. You get what you pay for and this is particularly true for these. Simply put, they are the best C63 headers out there in terms of sound, fitment, performance and heat management. It took a long time for Weistec to release long tube headers for the C63 AMG but their R&D is top notch and above the competition. Included with the exhaust manifolds are 3” Stainless Steel Midpipes, and a 3” Stainless Steel X Pipe. Bolt on installation that retains the factory resonator and mufflers. Price: $4,200 CAD ($3,142 USD as of March 26th exchange rate) + shipping x Weistec M156 High Flow Cats C63 3 Inch Inlet and Outlet 200 Cell Construction Minimal Flow Restriction Reduces Tailpipe Odors + Cleaner emissions Price: $1,250 CAD ($935 USD as of March 26th exchange rate) + shipping x KW V3 Dynamic Damping Control (DDC) coilovers KW V3 DDC coilovers with ECU option of using KW's App control + individual set ups in a push of a button. The KW DDC coilovers are part of the KW iSuspension program - the intelligent suspension solution for vehicles without factory adaptive suspension. These combine the advantages of an adaptive damping system with a vehicle-specific aftermarket suspension solution. Lowering can be done via the composite spring collar on the shock body or on the height adjustable rear perch in the rear of the vehicle. -dirt-resistant trapezoid thread and the composite collar -retrofit electronic damper adjustment -3 damping setups: Comfort / Sport / Sport+ -operation by retrofit button or optional App -create personalized setups with the KW DDC App The coilovers with this electronically controlled dampers enable an intelligent suspension setup via App-control. This allows you to upgrade your car with an adaptive damper control, and to have the option to adjust via the KW DDC App to suit your driving style. You do not need any tools to physically adjust the dampers! The free KW DDC KW App in combination with our optional W-LAN module allows you to customize your own damper setup instantaneously. This is an amazing coilovers set for our cars for both use on the roads and at the track. Price: $4,650 CAD ($3,478 USD as of March 26th exchange rate) + shipping x 4 RAYS Volk ZE40 Matte Blue Gunmetal + 4 TOYO R888 *****RAYS Volk ZE40 Matte Blue Gunmetal***** Mint condition No stratches, dings, dents or anything - gorgeous Front: 19x8.5 5x112 ET44 Rear: 19x9.5 5x112 ET49 *****Wrapped in Toyo Tires Proxes R888***** Front: 245/35 19 Rear: 265/30 19 Heat Cycled for better performance and durability Mounted & Balanced 19" This set has not seen track use = almost new tires (used for a month on public roads) This tire and wheel package comes with the following EXTRAS: - M14x1.5 27mm Neon Chrome Conical Seat Lug Bolt (Pack of 20) - Volk Racing ZE40 Center Cap - Matte Blue Gunmetal (worth $75 a piece) - Volk Valve stems with Volk valve stem caps - 2 sets of 4 centering rings - free set of 4 Toyo Proxes R888 tire lettering Price: $5,990 CAD ($4,480 USD as of March 26th exchange rate) + shipping x C63 AMG Stage 2 M156 Weistec Supercharger System 672 HORSEPOWER, 662 FT-LB OF TORQUE (with appropriate high flow exhaust system) 2.3L Twin-Screw Compressor Module 1000hp Liquid to Air Intercooler Core High Flow Cast Aluminum T6 Hardened Lower Manifold High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y 45mm Boost Bypass Assembly Billet Aluminum Direct Drive Cradle System Supercharger Serpentine Drive Belt Hard Anodized Billet Aluminum Serpentine Idlers Johnson CM30 30 Liter/Min Intercooler Water Pump Intercooler Water Recovery Tank Cross Flow Heat Exchanger High Flow Fuel Rail System Molded Silicone Couplers Power-Steering Reservoir Relocation Assembly Included with the SC is the Weistec Engineering trunk mounted water tank upgrade for an increased cooling capacity (approximately 6 US Gallons). This comes with an easy drain access with large capacity ball valve drain system. Also included with the SC is Weistec's Oil / Air Separator System. The separator system vastly decreases oil retention by the engine. The system comes equipped with billet PCV adapter fittings for easy bolt on performance, and accumulates oil in the lower body which can then be drained and recycled during every oil change. Price: $11,250 CAD ($8,415 USD as of March 26th exchange rate) + shipping x M156 ROW Airbox Set with High Flow Air Filter Set These are manufactured with a much higher flowing mass air flow sensor housing profile which improves flow characteristics of the ROW Airboxes. The M156 High Flow Air Filters are “dry” filters, they do not cause issues with the Mass Air Sensors. These are a drop-in replacement. Price: $650 CAD ($490 USD as of March 26th exchange rate) + shipping x C63 Stage 2 Street Brake Package - Girodisc 360x36mm Front 2pc Slotted Racing Rotors - Girodisc 330x26mm Rear 2pc Slotted Racing Rotors - Porterfield R4-S Front and Rear Street/Track Brake Pads These are slotted and drilled rotors that actually vent correctly. Makes a huge difference in stopping power on the roads. These were used for 3 months last summer. Price: $2,550 CAD ($1,907 USD as of March 26th exchange rate) + shipping |
Are all of these parts brand new?
Man, those are some STEEP prices. Some are more expensive than brand new!
Originally Posted by chrisridebike8
(Post 7096262)
Sent you a PM
Where are you located and pics?
LOL those giro disc prices are our of control LOL
(Post 7096262)
GTFO
Originally Posted by C63fora2w1
(Post 7096347)
I didn't want to be that guy but since the ice has been broken.. The Row boxes can be bought for 300 new..
Not without pics for the wheels.
Edit: New, the wheels are about $880 per wheel, or $3,500 for all 4. When you factor in the extras, including tires, it's a decent price. |
Pics. Dyno charts. Reasonable prices. All of these things make for a good FS thread. This is not one of them.
(Post 7096384)
Not to mention a brand new Stage 2 kit is only $1500 more. Yeah, I know this has a couple of exrras but a new kit comes with warranty. No way the OP gets any of these prices on the go fast parts. The wheels and suspension...I don't know. Maybe?:nix:
Originally Posted by Ambystom01
(Post 7096385)
(Post 7096384)
TBH, I really believe both the wheels and suspension are decently priced given the extras that come along with them. |
(Post 7096330)
Originally Posted by BLKROKT
(Post 7096391)
And as far as prices are concerned, these can be discussed. Most of the parts listed here are very high quality parts from respected manufacturers. You get what you pay for, these are expensive brand new, and not very common on the used market for this very reason. |
Originally Posted by L.C.A.D.
(Post 7096449)
Pics are available. I'll add some. Dyno numbers? what for? this is not a performance thread, it is a FS thread. Dyno numbers will vary from one car to the other depending on one's car and mods anyways.
And as far as prices are concerned, these can be discussed. Most of the parts listed here are very high quality parts from respected manufacturers. You get what you pay for, these are expensive brand new, and not very common on the used market for this very reason. Good luck~ |
Originally Posted by I am Jeff
(Post 7096464)
Since you're emphasizing that this is a FS thread, then post pictures of your very high quality parts that you are asking a premium price for! :slap: While your parts are a premium and I believe that you paid out of your butt by purchasing the parts from Weistec, I highly doubt that there are many who would be willing to be your sacrificial lamb on this forum and pay your prices. If you did your research, you'll realize that Weistec is a reseller, they mark things up. "Weistec headers" are a 4-1 design that is made by MBH, you could have had brand new MBH headers for the price of your used "Weistec"headers. For even less money, you can by the copied MBH headers that are sold by Autotalent for half the price. Those parts are not common on the used market because, most people on this forum do their research on the parts prior to paying full retail + markups for the parts that you are selling...
Good luck~ I did my own research prior to purchasing these parts, thank you, and we may have different sources. The debate on headers design has been discussed a lot on this forum, and this thread is not there for that. |
Guys, please consider that prices listed are in canadian dollars first, not USD. I thought the weak canadian dollar vs us dollar would make prices more appealing for you, but please make sure you don't mix both while reviewing the OP.
Interested in the kws
I need mid pipes and kws xD
(Post 7096449)
1 Attachment(s)
(Post 7096500)
You advertise it as "672hp" all over your post. So a buyer would expect to achieve those numbers if they were to purchase these parts, or at least that's what you make it sound like. Where are the dyno charts that show that this setup made that power? I think that's a reasonable ask, not trying to be a dick.
(Post 7096510)
I understand your point. These are Weistec's advertized numbers.
Where did the other 134hp come from? |
