CLK55 w/ K&N dyno numbers
CLK55
That was me - but until recently I could not post....
You can go digging in this directory that I have on my CLK55 on AOL (I know - sucks as an FTP site... ) but it has dyno results, the spreadsheet in excel, pics of the exhaust from under the car while up on the lift... etc.
http://members.aol.com/clk55amg2001/Dyno
It DEFINATELY gives you horsepower:
3.7 hp (at the wheels)
11.6 lb/ft torque (at the wheels) - yea baby!
Oh, Mr V was saying that there was like a 10+ hp gain - actually that is true as well - just look at the spread on the hp curve on the lower RPMs. I was stating "peak" figures above.
I just looked at the original spreadsheet again. The Max hp gain is 15.7 hp at the wheels at 4400 rpm, with the average hp gain from 3700 rpm through 4900 rpm is 11.36 hp at the wheels.
Not bad for the dollars spent - even if you only drop them in at the track!
Other random pics of the CLK55:
shell
clk55
shell
clk55
...but there is a noticeable drop in both power and torque below 3700 rpm... at least, according to the dyno graph... interesting. This means, the car should be a little slower off-the-line? Can you please verify?
CLK55
shifting
I think part of the issue is where the dyno technician / driver has to hold the rpms above 3K before he floors it so the car does not down shift.
Even when manually select the gear on the dyno, the car would downshift to a lower gear if the rpms were too low.
So, I think part of the graph on the low rpms are skewed because the driver has to try to hold the rpms, turn on the data logging, and then "roll" / hammer the accelerator.
Is Lincoln (new M3) on the list still??? He was there when I did the runs. Maybe he or Mr. Vanos can testify / explain this better. But I think it is an issue of how fast / hard the driver can get on the acceleration to WOT to prevent downshifting.......
