Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Ml 55 Lacking Go
Old Sep 11, 2007 | 05:01 AM
Blackhawk20's Avatar
ML 55 AMG
Ml 55 Lacking Go
I have an Ml 55 AMG which is performing poorly. If you kick it off the line it is very slow to get away but does wind up eventually. It has no problem reving out, however the changes are sloppy, it seems to "flare" especially form first to second. Once you get into third gear it gives some resemblence of what it used to perform like.
Any suggestions? It has been looked after by the Merc dealer in Melbourne recommended by Merc Australia after we had to have the heads replaced due them "carboning up". They were cleaned whilst on the car a couple of times but it really made no difference. The other problem which also led to the head replacement was the death rattle on start up. Sounded like a big end bearing running dry. Anyway the heads were replaced and it has never been the same.
I was so frustrated that I had it dyno'd. The pull was in third gear and the results were exactly as per the specifications 510nM and 260 kW. But the performance has never been the same.
I got some great help from this site recently on another problem and thought I would try again.
Regards
John
Old Sep 13, 2007 | 02:23 AM
jeff.bisonett's Avatar
2001 E55K
Have you checked the MAF sensor?
Old Sep 15, 2007 | 10:00 PM
ML 55 AMG
No. Where do I find it?
John
Old Sep 17, 2007 | 01:49 AM
2001 E55K
under the hood In the NA E55 it's near the firewall, just before the throttle body.
a couple articles to look at in your diagnostics:
http://mercedesshop.com/shopforum/sh...&highlight=MAF
oh and try out the search, there is lots on info on MAFs
