TVT 250 for the 3.2L v6 engines
Former Vendor of MBWorld
1 Post
Chrysler Crossfire
We've had the TVT250 kit available for the Crossfire crowd for quite a while now and are starting to get some feedback from drivers getting on the dyno. Everyone is loving it!
For the Crossfire the kit consists of:
Modified Airbox (or cold air intake)
High Flow Filters
ECU Reflash
Hi-Flow Injectors
We saw 253 HP with the modified airbox and 261 HP with the Cold Air Intake. We are offering two different kits for the Mercedes Crowd, both of which are sure to please.
Option 1: 1200.00
Custom ECU tune
Larger Injectors
This is perfect if you already have KN or similar filters and want over 250 HP. The MB airbox already outflows the Crossfire one.
Option 2: 850.00
ECU Reflash
Larger Injectors
Air Filters
This will get you to over 250 HP as well and is designed for a car that will not see additional modifications.
The difference between the custom tune is the Reflash changes the speed limiter and only effects WOT performance. Also all reflashes are the same regardless of other mods. With a custom tune we tune part throttle maps as well as WOT maps. This will allow your car to be faster ALL the time, not only when you race. We will custom tune for any future modifications as well for a $100.00 service fee, this stands for life.
You can see the dyno sheet on our site: http://www.tvtdes********/inc/sdetail/503
Please ask any and all questions.
Thank you,
Anthony
TVT Design
High Flow Filters
ECU Reflash
Hi-Flow Injectors
Option 1: 1200.00
Custom ECU tune
Larger Injectors
Option 2: 850.00
ECU Reflash
Larger Injectors
Air Filters
Thank you,
Anthony
TVT Design
