Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Question about LSD
Old Nov 23, 2008 | 03:37 AM
@nv@'s Avatar
2008 S63 AMG, 2008 ML 550
Question about LSD
As I understand the LSD redistributes power to the wheel with the strongest "grip"
Wouldn't this cause excessive spinning in ..losing control.. situations?
Any cons with getting it for regular driving, not racing all the time?
Also if someone can explain in laymen's terms the workins of LSD would be great.
Old Nov 25, 2008 | 01:24 AM
@nv@'s Avatar
Last piece of intel i got - lsd's make sense if you're planning to drift.
which makes sense to me.
Anyone else care to shed some light?
Old Nov 26, 2008 | 12:59 AM
whoover's Avatar
'19 E63S sedan
An LSD prevents spinning by routing torque to the wheel that has traction. It does the opposite of causing excessive spinning or losing control.
The negatives are increased tire wear (it interprets the outer rear wheel's normal higher rotational speed in a curve as "slip" and transfers some torque to the inner wheel, causing some wheel scrub), increased maintenance (LSDs need regular oil chanes) and some handling oddities that you need to get used to when pushed hard (understeer/oversteer changes).
Old Dec 8, 2008 | 11:52 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
For normal driving, especially with traction control, the LSD does not really come into play very much. It is a good option to have if you have lots of winter weather or if you plan on having any track days.
Old Dec 9, 2008 | 11:43 PM
qianlimoro's Avatar
fleet vehicle
oh.
wrong LSD. never mind.
Old Dec 10, 2008 | 03:13 AM
Untertürkheim's Avatar
LSD is great, it also will allow you to drive with less ASR intrusion.
