Kleemann Transmission Control Upgrades
Would this benefit the E55(W211)? Also, is the RAT available for the E55? Does the the tune or RAT leave any trace after being flashed back to stock? What kind of gains does the Kleemann tune show w/ an E55? Thanks.
Former Vendor of MBWorld
W211 E500 Estate
As far as the ECU programming, both Kleemann and Renntech offer several different levels depending on the other mods you have/want. I'd like to keep this thread dedicated to the Transmission Control Unit programming, so if you'll PM me the mods/power level you are looking for, then I can go over the options with you.
W211 E500 Estate
More aggressive downshifting while braking, faster shift speeds, will hold gears longer. The transmission will behave more like it does in an AMG car, basically. Load limitations are also removed, which would come in handy if you were to bolt on a Kleemann supercharger
Not familiar with the Kicherer box, but the Kleemann KD-Box is a great plug-and-play upgrade for the CDI and early BlueTec diesels (non-AdBlue). Easy install and great power gains for the money.
#32
J have a MB 250 turbodiesel motor with 722.616 end EGS51 installed in G250GD. Can You help me to put in function transmission without ABS and ABS sensors. Car is only off road used and don need any automation's. J can buy a EGS52 too.
