Evosport V6 and V8 Performance Ignition Stages I and II
We recently completed r&d on our V6 and V8 Stage I Ignition upgrades for all 1998+ V6/V8 Mercedes-Benz Engines. Included in Stage I are Evosport 8mm Performance Ignition Wires and colder irdium/platinum spark plugs. Gains of better response, smoother acceleration, and up to 10hp at the wheels can be expected depending on the motor, modicifications, and mileage.
-Stage I Pricing-
V6 Models: $559
V8 Models: $729
**Introductory Special**
For the remainder of the month, our Stage I Ignition Upgrades will be on sale for $479 and $619 (V6/V8 respectively).
Stage II:
With Stage I completed, we are beginning testing on Stage II, which will include the integration of a multi-spark capable CDI Ignition box, able to produce sparks of over 50,000 volts--nearly 50 times greater than stock!
The increased power will allow us to use much greater gapped spark plugs, and thus increase engine responsiveness, efficiency, and power output.
Stage II will begin testing on my car in the coming month, and should be available by Summer '04. Those who purchase Stage I will be able to upgrade to Stage II through purchasing our upgrade package when available.
Thanks,
Ben
What are the gains of Evosport 8mm Performance Ignition Wires with stock plugs? I just changed mine 2 weeks ago, and dont want them to go to waist :/
Without changing the plugs, should the wires increase performance? Sure. The question is just by how much. The answer of course varies with the car
. Theoretically, new stock wires and plugs on a car with 40,000+ miles is beneficial (to a lesser degree of course), so adding our wires with your plugs should help as well. However, for the package value, I would recommend purchasing bothhh and either using the plugs or saving them for later.Thanks,
Ben
Also evosport guys, can you tell me what size belt to use on my v6 if i have the pullies installed. thanks
With that being said the factors that will impede the required voltage from being achieved are:
-resistance between the center electrode and the ground electrode (newer, cleaner, sharper edges, less resistance vs. used and dull) (iridium and platinum are more wear resistant)
-heat of coils, wire's, plugs (any component that will carry current will be affected by heat as heat goes up so will resistance so a properly insulated wire will be less susceptible to radiated thermal energy)
-dwell time of the coils will also limit how much voltage will be achieved at the plug.
As the engine speed goes up the time required for the coils to energize fully goes down, this will result in less voltage available at the plug to fire the air gap and as the engines power output increases, the required voltage to jump the spark plug gap will go up while the time to achieve this goes down. The reason why aftermarket ignition systems work so much better is that they have the ability to not be bogged down with the compromising performance and costs of production that the OEM has to bear on such a large scale.
So in summation a plug that will require less voltage to jump the same air gap will have the ability to extract a greater operating range for fixed conditions, not to mention if they stay cleaner and sharper longer they will be consistently better performers. New wires that have less resistance and are better shielded will not hinder the voltage from making it to the plug. Lastly a good quality aftermarket ignition system will put more voltage to the plug consistently, and more importantly, will allow you to run a wider plug gap that will have the ability to catch a greater portion of the fuel/air charge by yielding a greater percentage of the charge to be used; which will in turn yield more power and better economy a win, win.
Thanks,
Ben
--Our pulley kits use a 6 Rib - 95"/2415mm belt.
if the car was having misfires, then the computer would pick this up. also why not just buy an msd and bolt it on, what is there to test at this point. also what size belt do you use on the v6 with your pullies.
Suggesting a MSD box is a step in the same direction, and acknowledgement that what we are doing works, however our system will improve upon many of its limitations.
Thanks,
Ben
Assuming that what I read is correct, then I believe that it stands to logic that the more fuel and air that you can burn during that initial first of the stroke, the greater the peak pressure, and therefore power. It seems even more logical when you consider how little time there is during each power stroke. I think of it like this: the naturally aspirated 5439cc V8 makes peak torque at 4000 rpm. Since the power stroke only occurs at every other revolution, we have 2000 power strokes per minute. That equates to an ignition firing every .03 seconds. Once again, if my information is correct, it's vital to burn as much furl air as possible during that initial 25% of the stroke, that reduces combustion time even more, down to .0075 seconds. Obviously not much time there. If we calculate burn time at 6000 rpm, there's only .005 seconds to burn as much mixture as possible.
I have to think that having a signifigantly stronger spark has to go some way to helping to burn as much fuel/air as possible. I also suspect that while the twin plugs are mainly for emissions, (please correct me if I am wrong), modifying the ignition phasing between the plugs could help take advantage of this as well.
Does my logic seem practical? By no means am I trying to pass this off as gospel. It really is just my opinion based on what I have read. At the risk of coming across as a wise acre, I am a bit curious about the pricing for the Evosport ignition kits. Is it really $729 for plug wires and iridium plugs? Are the wires integrated with the coils to the point where you are including the coils as well? I understand that the price also reflects R&D costs, but it still seems awfully high regardless. I respect Evosport, and I believe in their reputation, so I apologize if more is included, and it is just my ignorance of the product in question. Let me know what you think...
Best regards,
Matt
At 6000 rpm that equates to 2,160,000 degrees of crank rotation per min which breaks down to 36,000 deg/sec or 36 deg/.001 sec thats one one-thousandth of a sec. The first 25% of the pistions travel equates to 45 deg which means that in .00125 of a sec the engine will travel 45 deg. That is how fast things happen.
I am not agreeing or disagreeing to your 25% theory, as there are too many factors to get into. However, the above numbers are correct for you to use in your theories.
Don't forget, based on the degrees of crank rotation at 6,000 rpm, each cylinder has a dwell time of .02 sec before having to fire again. This is one of my above mentioned reasons of why we are looking into ignition systems that can outperform the factory at high engine speed and increased cylinder pressures.
FYI, with factory replacement parts, you are spending about $500; $100 less than our current special with zero gains. Remember, Mercedes uses 2 plugs per cylinder; you're buying 16 plugs and wires, not 8.
Thanks,
Ben
PS -- None of these are new ideas, they've been used on other cars for decades. The gains are no longer as extreme as before, but the end story boils down to, no car comes perfectly tuned from the factory.
HUBERT
Pricing is TBD, however I expect it to be a great value when complete.
Hubert,
Yes, not only does it work, but it works better, as some of the inefficiencies in the stock ignition system are worked out. I have it on my car! Stage II will really benefit your highly-modified 430. Feel free to call me tomorrow for more info.
Thanks,
Ben
I can definitely say this much. I had a 1991 Suzuki GSX-R1100 that had 1216cc, a port, polished, and bead-blasted head, 38mm flat-slide Mikuni carbs, a Yoshimura intake cam and exhaust system, and lastly, Dyna coils and Accel plug wires that supposedly had considrerably less resistance than the stock wires (They were much thicker). I did the coils and wires seperately, and while I'm not 100% of whether or not it gained power, it sure as heck revved a whole lot faster. It really was a pretty signifigant difference, and I know my mind wasn't playing tricks on me, because at the time, I didn't know that an upgraded ignition would make the motor rev faster. Throttle response was signifigantly improved. It also seemed to run much cleaner too. Not as much black smoke at w.o.t., and it lost some of it's intake-reversion-from-valve-overlap dip. It just revved right through it. I didn't expect really much of a change at all, and I was very happy with the results, so i'm sure that we can expect at some improvement from the Evosport kit as well. Thanks again for all the information!
Best regards,
Matt
Hey, no worries! I commend you for putting that much thought into your post; regardless of the outcome. It's healthy questioning like yours that helps us all to learn, and even better -improve upon, new ideas.
A stronger/faster spark can allow the engine to be more productive, as there are less inefficiencies (delays) keeping ignition from occurring at the most precise moment. Anytime you remove an inefficiency in a car, you stand to improve upon it. Whether it is brakes, intake, exhaust, motor, or whatever, nothing comes perfectly tuned from the factory--these aren't Enzos we're driving.
You are correct in your assumption that supercharged cars, or any highly-tuned motor, will benefit more than most stock motors. However, as you said, all motors stand to benefit.
Thanks,
Ben
We have seen 9hp at the wheels on a C32 w/ our Stage I upgrade. I have noticed gains on my car, but have yet to dyno them.
The reason why e36 plug wires provide no gains is because the coil sits directly on the spark plug--there are no wires. Whereas the e30 had a distributor which powered all plug wires directly.
ronnie0738,
As soon as we have the CDI wired to my car, I will post results.
Although we have used and recommended Denso's in the past, we found a new solution that has provided a significant improvement. The plug we are currently recommending added 3 whp across the powerband on our race car on back to back dyno runs. It is also better suited for the stresses of a tuned motor and longevity. I have nothing against the Denso plug, however to put it in perspective by comparing it to the NGK we are using now, the closest Denso plug is about $35 per plug.
It is our never-ending quest to bring you the most current and up-to-date products. If we had a brand allegiance, we would only be pushing one brand, and stayed with Denso. But then we would be standardizing, not customizing.
Theine,
The more modifications your engine has, the more these upgrades will help. They will work great on a stock motor, but they will work greater on a modified motor.
Thanks,
Ben
As wires are made from conductors, resistance between different wires would primarily be based on the ability of the wire to conduct current, which would be controlled in the first order by the diameter of the wire. Secondary orders of contribution would come from the conductivity differences between different conductors and length of the wire. Unless the existing wires are corroded, I doubt there would be much of a difference in resistance or impedance between stock and upgraded wires.
I will agree that if you supply a greater voltage to the plug and you increase the gap size you will start the combustion over a larger volume of the air-fuel mixture and that could lead to some increase in power. I have no clue how much that would increase performance however, the amount of air-fuel directly set off by the spark is likely not that much and the effect of a small increase in that amount by lengthening the spark is questionable, given that the chemical reaction thereafter should be primariliy dictated by the pressure of the atomsphere inside the cylinder.
Further, if the voltage were increased without increasing gap size, not much would change as the spark will still form at the same voltage and once formed, the spark will ensure the voltage will be at the breakdown threshold voltage dictated by the gap size and material content of the air-fuel mixture.
just my opinion.
