Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
K & N air filter
Old Nov 14, 2017 | 07:03 PM
roger23's Avatar
Registered User
2010 E550 / 2012 ML 550
K & N air filter
Would installing a K & N performance air filter make a noticeable performance improvement to my AMG ?
Are there likely to be any warranty issues with the vehicle, if that air filter is installed ?
Old Nov 26, 2017 | 10:55 PM
Cifdig's Avatar
Top Answer: 1
2007 e350 sport. 2010 350 4matic sport. Worlds first W212 E63R self built.
i have it and have no issues. Definitely more responsive from the increase in air flow. Do a tcu reset when installed that way you can get a better feels for it and not let the tranny delay affect your response
Old Nov 27, 2017 | 05:12 PM
retvethogrider's Avatar
2015 E550 Coupe
Cifdig—how do I do a TCU reset? Thanks
Old Apr 30, 2018 | 01:17 PM
Billmiranda's Avatar
2014 E63 S-AMG Wagon
http://www.mercedesmedic.com/reset-m...-instructions/
Old May 13, 2018 | 08:47 AM
skylolow's Avatar
2005 SL55 Completely Built Motor
I have them on mine. But I can't really say they do much. I guess best case scenario if you ran back to back dyno runs maybe you'd gain a couple HP's at best.
I would look at as more of a long term solution from having to replace them yearly or whenever.
Old May 13, 2018 | 09:12 AM
Jan AMG's Avatar
The best or nothing
It's totally useless. My friend, a huge KN fan made me buy KN filters for all my cars including two identical CLS63S's. We then ran a series of tests head to head, standing starts, dynamic starts.. and I can tell you NOTHING happened in terms of performance.
He, of course, before the tests, was claiming how the turbos sounded better, how the air sucks in faster and he could hear it, how it adds at least 10hp.
So unless your car is heavily modified, in which case it might (or might not) add 1hp, it is utterly pointless.
Old May 14, 2018 | 12:15 PM
Cory @ Weistec's Avatar
PLATINUM SPONSOR
W204 C63 AMG
Hey Roger, K&N filters are generally oiled to help remove air particulates, but the oil has been known to cause issues over time by slowly coating vehicles Mass Air Flow sensors. You're better off with a dry filter, and something that is developed specifically for the AMG platform .
Our filter offerings here at Weistec are specifically designed and tested on AMG vehicles and are dyno proven to gain 5-10whp when tuned over stock!
Old May 14, 2018 | 01:49 PM
C280 Sport's Avatar
MB’s of all kinds.
0 gain is what they are. Honestly a clean OEM filter is just as good.
Old May 18, 2018 | 09:50 PM
MBspdfrk's Avatar
2014 ML 350 Bluetec
Zero benefit. They flow more air, and they flow more dirt. I used them on a modified dodge-Cummins with over 500 hp to the rear wheels, pulling in excess of 40lbs of boost. Do not waste your money.
Old Jun 28, 2018 | 08:08 AM
happyeds's Avatar
2018 S560
Roger23
K&N started in the 1960's. Automotive manufacturers at the time used "oil bath" and "cotton" filters which were very restrictive and hard to maintain. The industry was transitioning to a paper filter in the early 70's but were even more restrictive because of the paper technology at the time. K&N started marketing the cotton and oil concept in a more manageable form. The K&N filter was more free flowing because they could adjust the amount of cotton and oil depending on the application.
This is 2018, 50 some years later and today automotive air filter paper is a science onto itself. Absolute dry air is the best friend of your ($$$$) mass air flow sensors. If you use an oil saturated filter (from the 60's) is your air really clean? What happens when you clean the K&N? Are you positive your mass air flow sensors will enjoy the taste of fresh oil? Hum
Old Jul 2, 2018 | 11:37 AM
oldsinner111's Avatar
s320
been using them over 12 years,no problem if you clean and oil them right.Only spray oil on side of filter that gets fresh air.If in dusty area use a sock over air filter too.
Old Jul 3, 2018 | 04:42 PM
cm60k's Avatar
Prefer to go with dry filters, oily filters attracts more dust due usage..!,,
and also, they are a bad Enemies to the MAF films..
-;ZAYED;-
Old Jul 17, 2018 | 02:06 PM
jinark's Avatar
Veteran: Navy
2003 CLK 320 convertible
-;ZAYED;-
Same here. I much prefer the ease and convenience of replacing an OEM filter every couple of years. a filter engineered for the car by the people who built it.
A comment on HP gains. Besides the number of HPs a filter is said to add it's useful to know at what RPM that occurs. A 5 HP gain near and at the redline will seldom if ever be used or felt by the average driver.
Old Jul 18, 2018 | 12:49 AM
cm60k's Avatar
{{^^--WELL SAID--^^}..
-;ZAYED;-
Old Aug 9, 2018 | 03:01 PM
yaknart33's Avatar
2010 E550 coupe,2005 porsche ca 911,04 subaru outback,94 Harley FXSTC
I am retired senior master tech ,gas and diesel over thirty years experience at ford dealer.This is my opinion based on stock vs K N air filters using data monitoring factory test tools.The K N works good on a carbureted engine ,but with a EFI vehicle it does'nt add HP or torque, it can change the power curve slightly.I monitored data from a mustang gt ,f series truck,and a ranger .There was no difference in data from the factory air filters compared to the K N filters.Timing ,fuel control ,fuel trim ,etc, all data was virtually identical .The one thing that did increase performance was the size of the air inlet ,on some fords the inlet was only 3-5 inches in diameter.I enlarged the smaller openings to 6-8 inches and that increased air flow and the EFI was able to increase fuel flow ,timing ,etc that did improve the performance slightly.My E550 has good air flow with stock filters ,as noted by others the oil on the K N filter causes restrictions and will coat sensors and cause check engine light to come on.The mass air flow sensors are contaminated quite often,sometimes they have to be replaced. I have K N air filter on my highly modified carbureted Harley,and my boat, it makes a noticeable difference .This is my opinion based on my experience and using factory test tools for many years.The factory filters do quite well just keep them clean.
