m111 oil catch can conversion, advice sought
I have attempted it and and now getting oil blown out through the dipstick; so I am clearly sending pressure the wrong way!
I have fitted an oil catch can to my 2003 W203 200 kompressor with m111 engine.
I am getting oil blow back through the dipstick. I am pretty sure the routing is ok and have even fitted a non return valve on the thin pipe between the crank case and supercharger manifold as I thought that maybe pressure was coming back up that pipework but that hasnt helped.
Any advice as to why this is still happening would be much appreciated.
On catch cans, they should intervene between the crankcase breather then directly into the throttlebody, or intake manifold port; wherever the PCV might have been. I've setup a number of CCs on other engines. My goto source and CC preference is MightyMouse. Catch Can | LSX | Mopar | Ford | Mightymouse Solutions | Virginia, USA.
You might try them with some Qs and better pics. They'll know right where to route.
BTW, based on where you are located, if a visual/equipment emissions inspection is done, this will fail as you are now venting crankcase vapors to the atmosphere.
