Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
unknow oil leek ML500
Old Jun 10, 2009 | 10:01 PM
will8855623's Avatar
ml500
I have a 2003 ML500. I just got my oil change about 2 weeks ago and just started having a oil leak. I have checked the seals and plug. It seems to be coming from the upper drivers side. I have attached a pic of what I think the problem is but I am not sure. You will see a hose that I have stuck a bolt in that come up from the bottom of the car and ended where you see. I stuck a bolt in the open end so that you can see what I am talking about. IS this suppose to connect to something? HELP!!!
File Type: pdf
