Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
2007 E550 SOS auto-dial - no TeleAid Subscription!!
Old Sep 24, 2009 | 12:20 PM
texanMB's Avatar
E550 2007
need some help - checked for 2007 recalls for GPS antenna, there seem to be none. I am not signed up for service, had an accident where airbags deployed, and SOS system auto-dialled 911 in a continuous loop. Instead of disconnecting [as i was told would happen with no 'active service'], i was actually connected to operator and each time after i clearly said 'no asistance required', the SOS system auto-dialled out again [each time i connected with operator ..??] I was not injured, but emergency personnel arrived on scene and now City is poss going to charge me with 'abusing 911' services... what can i do - where can i get info on prior possible malfunction. Had system tested - MB dealer error report from Tech2 stated 'tested GPA antenna signal and found 4.7volts. R&R headliner partially in rear and found poor connection in GPS antenna. Reset and Reprogrammed antenna'. This is crazy - need some help. I never signed up for this - was not eligible for 'free 1-yr service' so dealer did not 'auto-sign up' they tell me, as car was used when i bought it 2008, it is a 2007!!
