Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
C280 antenna wont retract
Old Jan 23, 2010 | 08:01 PM
vartkes's Avatar
c280
The antenna on my 1997 C280 wont go down. Does it need to be replaced or is there a simple fix?
Old Jan 30, 2010 | 01:06 PM
bennesspipers's Avatar
'95 W202 C220,'96 W210 E230 Est
Hi, if you're a carefull sort of guy you can take these apart, usually its just filled up with muck & dried out, & a thorough clean & light oil of the mechanism will sort it. If you find that the nylon aerial tail has had it you can either buy one from MB or off E-Bay. Hope this helps.
