Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
rough idle
Old Nov 18, 2011 | 10:47 AM
jsip's Avatar
2002 C240
rough idle
My 2002 C240 with 140,000miles started to have a rough idle, while in drive, at low RPMs. It feels like the car is going to stall but never does. No CEL on.
I had a tune up about 18months ago with all coil packs, plugs and wires changed. Recently took to a garage that specializes in MB and had Harness wires changed, engine diagnostic done, engine mounts were OK with no fix. I was give injector cleaner to add to my next fillup to see if that corrects the problem.
Any other suggestions? Garage recommends a compression test to check the engine, if everything checks out good then move to bench test the injectors.
thanks!
